Xantia return pipe
froggy
(Donor 2026)
x 4
Xantia return pipe
Unread post by froggy »
Hi, my S1 Xantia, has a hydraulic leak on a return pipe fitting. the fitting is Y shaped and the pipes push into the fitting. is it possible to still source these ? thanks Terry. the fitting has split ! :cry:
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
petef
x 11
Re: Xantia return pipe
Unread post by petef »
Some return piping may still be available from Citroen, I got a Y piece not so long ago. Or https://www.chevronics.co.uk/product/bx ... ts-xantia/ from Chevronics. Personally I use aquarium fittings, which work well and are not attacked by LHM.
x 1746
Return pipes are not under any real pressure, and are frequently joined together, on their way to the reservoir.
The exception is return from the steering, which shifts sizable quantitities of LHM.
The returns from suspension items are quite small, so any reasonably sized Y- or T-piece should suffice for rubber piping; nylon return tubing will require rubber elbows/couplers, which are still all available from Citroen.
froggy
(Donor 2026)
x 4
cheers :-D
Terry
