C5 Mk1 vague gearchange - 2.2HDi
aramsay
Unread post by aramsay »
Hello.
I have an 02 plate Mk1 C5 Estate, 2.2HDi , ~217,000 miles
The gearchange is getting increasingly vague, especially for finding 1st......more usually reverse ! [-o<
I'm assuming it has a cable arrangement that is getting worn, or linkages.......
Can anyone suggest what might be wrong, and what I should look for ?
x 6955
Re: C5 Mk1 vague gearchange - 2.2HDi
First and reverse gears are usually the hardest gears to shift into. It may be the clutch not releasing fully, which would make it symptomatic of this problem.
There is a technical bulletin describing this issue that I'll PM you about.
