Peugeot 306 Crankshaft Sensor location
King222
Unread post by King222 »
Hello! Apparently I need to replace my crankshaft sensor, the problem is I'm not able to find it and I can't find anything online.
The only thing I found was this video
[Admin Note: Video Link Removed - Video Not Available]
Is that it?? That is where the cranckshaft sensor is located?? If so, how can I extract it???
My car is a Peugeot 306, 1.6, gasoline, year 2000.
Thanks!
Reason: Video no longer available
x 1056
Re: Peugeot 306 Crankshaft Sensor location
Unread post by wheeler »
In that video its the part with the yellow plug, which is odd as the plug is normally black. Cant think I've seen one with a yellow plug before. Its just held on with one 10mm bolt.
King222
wheeler wrote: 11 Aug 2020, 18:07 In that video its the part with the yellow plug, which is odd as the plug is normally black. Cant think I've seen one with a yellow plug before. Its just held on with one 10mm bolt.
Ok, mine is also yellow and I got that one located, I even unplugged it for a moment just to check if that was the one but I wasn't sure.
So I have to unplug it and extract the black part, right?? Because the sensor looks like this:
So if I extract the black part, that's exactly what I'm going to find, right?? like the one in the photo.
x 1056
It will come out together with the bracket, the one in the video is also a different type to the one in the picture above, the one in the video has an all plastic bracket. the on in the pic is a metal bracket but it is fixed on, you dont remove the metal part, the new part will come complete.
King222
wheeler wrote: 13 Aug 2020, 18:36 It will come out together with the bracket, the one in the video is also a different type to the one in the picture above, the one in the video has an all plastic bracket. the on in the pic is a metal bracket but it is fixed on, you dont remove the metal part, the new part will come complete.
Yep, you are right, I did that yesterday and was exactly how you described it. Many thanks!!!
Treksio
New User
Unread post by Treksio »
Hey guys do you have another video of where the sensor is as I have been looking for a while now and cant seem to find it
Huskyxantia
x 864
Unread post by Huskyxantia »
Treksio wrote: 20 Apr 2022, 14:43 Hey guys do you have another video of where the sensor is as I have been looking for a while now and cant seem to find it
https://www.google.co.uk/url?sa=t&sourc ... Y0f3XzyeYz
:-D
