Lexia 3 can it check fuel pressures?
New2ds4
Unread post by New2ds4 »
I have a problem with code p0087 low pressure at the rail and wanted to check the fuel pressures at the tank and the fuel pump wondering if I get a lexia 3 off eBay will it b able to check the pressures any help would b much appreciated
x 1056
Re: Lexia 3 can it check fuel pressures?
Unread post by wheeler »
You don't say what engine you have?
If its a Diesel You can read the pressure from the fuel pressure sensor with Lexia, thats assuming of course that its not the sensor itself thats at fault.
some petrol engines can have a fuel pressure sensor too but im not aware of being able to check the low pressure in tank pump with diagnostics, you would need a fuel pressure gauge for that.
New2ds4
I’ve got the 200 thp
