2007 Citroen Dispatch oil leak
aearl54
New User
Unread post by aearl54 »
Hi everyone,
I was just wondering if someone would be able to help me I have 2007 Citroen dispatch 1.6hdi. I had to have the injectors replaced last year and ever since then it’s been leaking oil and pooling around the injectors. I then took it to another garage to have them look at it and they said the seals on the injectors hadn’t been replaced and that the inlet manifold ones needed doing. But it’s still leaking and pooling with oil. So if anyone has had problems like this or knows what it could be would be much appreciated.
x 6945
Re: 2007 Citroen Dispatch oil leak
It's critical in these 1.6 Engines to ensure the washers and seals are intact and that the injectors are correctly torqued down and rechecked. It's the source of so many turbo failures if this is not done,
Details of the issue here:
viewtopic.php?p=650153#p650153
