Coolant leak
JohnR
Coolant leak
Can anyone advise. I have a Clio 1.2 (think e type engine). I have found a coolant leak at the front of the engine where the straight plastic or metal pipe which goes into the block ( presume water pump)and connects up the rubber hoses. Is this a push fit . Is it just a seal and if so can I purchase without buying a water pump if that is where it goes in. How simple a job is it?
mdh_74
jeffo
