Working from the instructions posted by Jon I renewed my rear sphere's and what a difference, no more bouncy bouncy.
The only thing to watch out for is a small rubber gasket, I did not fit them properly first time and LHM was leaking everywhere.
Make sure they are flush in the recess of the cylinder that the sphere screws into.
For a removal tool I used the idea of a screwed rod bent around a sphere through a bar and tightened and it worked a treat, didnt need to touch the pipe to the cylinder.
Small issue now is when I start up the suspention drops and after 20seconds or so starts to rise again, It's a VSX and hydractive (has sports suspension button) so I dont think it should drop, does this mean accumulator spere is faulty?
Renewed rear spheres
philhoward
AndersDK
Be sure to do the Citaerobics before suspecting anything else.
The rearsink is not caused by the Hydractive sytem, it's the anti-sink that does this. You're right that the main accumulator (on engine block) can do this - if it's weak - when first starting the car.
But then you should also have frequent ticking from the pressure regulator - the unit on engine block the main accumulatr screws on to.
The frequent ticking would appear constant - independent of engine (and then pump) rpm's - after system initially has stabilised.
A ticking interval lower (i.e. faster) than approx 30 seconds points to a weak main sphere, whereas rapid ticking indicates a failed main sphere.
The anti-sink system would have it's own rear middle located sphere for the rear brakes. This sphere is recognised by having a single standard 3.5mm rigid pipe connected.
This could need replacement too, sometimes being the cause of a dropping rear on start, if it's weak. It would only cause a minute drop if it's flat.
It would NOT be the cause of frequent ticking though !
big_lorry
