DS3 Crossback Boot Liner
cowenb
Unread post by cowenb »
Hi all,
I recently bought a boot liner to fit into my boot but for some reason it just won’t fit.
The edges are contoured as if it would fit but it doesn’t and I assumed there would only be one boot liner available for the crossback.
The part number of the one I ordered is: 1638366480
Is this the right one or is there another one I should order that would fit?
Thanks in advance 😊
x 6950
Re: DS3 Crossback Boot Liner
That is the correct one for a DS3 Crossback, but we can't help you with parts info for these newer DS3 Crossback (D34) models unfortunately, only the earlier Citroen - Badged versions.
cowenb
Hi Marc,
Thanks for your reply.
This is the only DS3 Crossback that has been made, what do you mean by the Citroen badged versions?
x 6950
I meant we only have parts data for the Citroen DS3,4 & 5, none of the Crossbacks which are only DS-Badged
TheBadger
x 5
Unread post by TheBadger »
Not sure if this will help in the case of a DS3 Crossback, but I bought a boot liner for my DS7 Crossback which also didn't fit, until I realised it was designed to go in the boot under the false floor that you can remove to make the boot a little bigger.
