I have been getting a "Worn brake pads" when I first drive away of a morning so I'm assuming they need replacement.
Before I get started, is there any special tools needed such as one to retract the pistons or can I just push them back (jemmies or g-clamps normally work)?
Regards
John
C8 disc pad replacement.
jscadden
- x 4
John
Xsara Picasso VTX 16V
VIN VF7**************[VIN obfuscated, can be read by forum staff]
- x 6945
Re: C8 disc pad replacement.
The front pads can be fitted by pushing the pistons back carefully - but on the rear ones, they need a wind back tool.
Also, be aware that if your brake fluid reservoir is at the max. level, you'll need to take some out after removing the filter, using a spotlessly clean syringe or similar, so as not to cause an overflow of the fluid onto anything when you push the pistons back.
