Rd45 pinout location for rca audio
McLaughlin15
Hi, ive changed the headunit from my c5 and it had an alpine head unit, so I've bought an rd45 but the rca wires are in the wrong part of the block because my car must have come with the rd4, does anyone know which part of the block the rca wires go into because at the moment they dont touch anything on the head unit, thanks
- x 6950
Re: Rd45 pinout location for rca audio
The rd4 and rd45 should have similar quadlock connections, so check that they haven’t fitted an aftermarket harness to interface with the Alpine unit into the vehicle’s wiring system first of all.
I’ll get some pin info for you shortly
McLaughlin15
The iso connector they put in for the alpine has been taken out and im just left with the original wiring now but the pins out the radio are not in the same position as the connector and thankyou
- x 1481
The pin numbers for the RCA connectors are given in diagrams on the first couple of pages of: viewtopic.php?t=58078 I think that there may be more complete pinout information later in that topic.
McLaughlin15
Cool, its on page 16, thanks for the help.
- x 6950
If you need anything else, let me know then.
McLaughlin15
Cheers, my usb cable will be arriving tomoz and I will be adding my own non standard mic using the diagram, I know they won't work because I'm going to have a guess that I will need lexia to open them up because I cant see them on the screen and does it have to be lexia, my wifes dad is a mechanic and is always showing me his fancy snap on diag tools and says they cost thousands, will they work with it?
- x 6950
Not quite with you when you say you need Lexia to "open them up"?
What C5 are you referring to a MK II (2004-2007) or the latest shape MK III (X7) 2008 on?
For configuration of the RD45, the VIN will need coding to the Head Unit and you will likely need to change some parameters. I can advise from a Diagbox point of view but not a 'Snap On' as I only use the PSA Kit.
McLaughlin15
Its the x7, its in the garage on wednesday so I will have a look and see if it can do anything, if not I'll be searching on here for someone around manchester who has lexia, my saab uses tech2, my Renault uses clip and now lexia,take me back to the old days when cars didn't have computers
McLaughlin15
Did the rca leads and I dont know why I bothered, is the sound supposed to be so bad and echoey or is there something else I should plug in them so I can get better sound
- x 1481
I never noticed a problem with the sound quality from the analogue input, but I disabled it anyway as I use a USB stick or bluetooth and did not want an extra input to scroll through.
