Citroen C4 MK3 2.0HDi engine fault
xantos
x 10
Unread post by xantos »
Hello everyone!
I have a problem with my misses C4 and it is above my technical knowledge to diagnose the problem. It's easy to fix my Xantia (all you need is a hammer :-D ), but I'm no too familiar with all the electronics that modern cars have. The car is a C4 Mk3 (B7) year 2010 2.0 HDi 150HP Exclusive.
The issue with the car is that "Engine fault, repair needed" alarm has occurred. I have a Lexia and erased the faults but and its good for a day or two then it reapers. The car otherwise drives ok, just sometimes it looses a bit of power. About a half a year ago the car went into "Limp mode" with a total loss of power and I erased the faults and it never reoccurred.
This picture is from back then when it went to limp mode:
And this picture is from now:
If someone can point me into the direction of investigation or which part needs to be changed I would really appreciate.
Thank you!
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
x 1056
Re: Citroen C4 MK3 2.0HDi engine fault
Unread post by wheeler »
Go into live data & see what the air flow is at idle & if it increases when you rev the engine.
