Blaupunkt Boston C22 code entry sequence
tomsheppard
Unread post by tomsheppard »
At last the window came up COD so I can now see if the code I was given is ok. I don't have the entry sequence, though and I know that after I've entered all the numbers that I have to hit one button to enter the finished code. Can anybody help, please?
James.UK
Unread post by James.UK »
On the standard radio fitted in the ZX you keep pressing button 1 untill the required number comes up, then do the same with button 2 and so on untill it reads the correct code, when you have entered the code you press the ^ (up) sign on the square box on the left hand side to lock your code in... [:)]
tomsheppard
Thanks James. looks like I have the wrong code anyway, alas!
