Citroen Relay N/S mirror
Benita
x 4
Unread post by Benita »
The nearside mirror on my 2010 Citroen Relay is almost impossible to fold in, it is extremely stiff.
I can not see any way of access to lubricate the pivots.
Can anyone help?
Thank you
Benita
Benita
x 4
Re: Citroen Relay N/S mirror
Problem solved.
Benita
x 3306
Well done. How did you manage it?
Benita
x 4
Hi Hell Razor
With no hints forthcoming I decided to drill a 3mm hole in the casing above the pivots.
I then flooded the space with light machine oil and let it soak.
Wrapped dusters around the arms to catch surplus.
I think I have caught all the surplus oil and the mirror is quite free.
Plugged the hole with a bit of black mastic.
Looks Ok
Thanks for your interest.
Benita
