Peugeot partner 2008 1.6 hdi glow plugs
Volvo350
Unread post by Volvo350 »
Hi has anyone got the wiring diagram for the glow plugs on peugeot partner 2008 1.6 hdi.
My van wont start, replaced glow plugs, but still didnt start, when I took them out to test they was ok and heated up, replaced pre heating relay but still didnt start. So looking for the wiring diagram if anyone can help please
x 6954
Re: Peugeot partner 2008 1.6 hdi glow plugs
The glow plugs are rarely needed to start an HDi in this weather - the fuel is ignited by pressure. I think you have another issue going on... possibly even immobiliser related. If you have Diagbox, get it hooked up and see what the engine ECU status is. If it's locked then, you may need to synchronise the keys / fobs - especially if you've disconnected the battery recently.
Procedure for battery disconnection / reconnection is here:
Volvo350
I have connected to my obd reader which displays p1351 pre heating curcuit. This why I think fault on wiring.
x 3281
That error seems to be a very common one on the HDi engines, and yet does not affect the normal starting (it may be a 'ghost' error). I have seen it on both my C5s, and neither has failed to start.
