Can anyone offer me some guidance on replacing an outer drive shaft boot on a 1997 Traffic van (2165cc five speed)I can strip down and release the shaft outer end and the joint but cannot see how to remove the joint to replace the boot also unable to find relevant handbook/manual..is it possible by a reasonably skilled diy person...any advice much appreciated
John A
Renault Trafic Drive Shafts
Homer
- x 16
Guessing a bit from my experiences with other cars.
Usually these are secured with a captive spring clip. Simply tap the joint with a mallet around where the driveshaft goes in. It is easier with the driveshaft completely off the vehicle.
Make sure you have a couple of spare spring clips before you start putting it back together. You are bound to break the first one.
lochar_Lady
There is a workshop manual for the Trafic with 2165 c.c. engine available from Peter Russek Manuals. www.russek-manuals.co.uk It has just been published.
