Coolant Temp Sensors Differentiation - 2004 Citroen C3 1.4i
breadcast
Hello. I have fault code P0115 - engine coolant temp sensor 1 circuit. My Citroen C3 has two coolant temperature sensors, an upper green sensor with two wires and a lower blue sensor with 1 wire. Does anyone know which sensor the fault code refers to? Thank you.
- x 3306
Re: Coolant Temp Sensors Differentiation - 2004 Citroen C3 1.4i
Hi, and
to the Forum. While I cannot advise you it will not take too long before somebody can help.
- x 1056
The green one is for the engine management system.
breadcast
Does the P0115 code apply to the green, rather than the blue, sensor? Thanks.
- x 1056
Yes, the green one, they are a fairly common failing part.
