Non Starter Xantia 110 hdi
Big Eb
Unread post by Big Eb »
Morning all. I have a year 2000 Xantia 110 hdi.been starting no problem then was just getting ignition light and no turn over. Tried a brand new battery still no turn over,even changed the terminals as positive was broken and still no turn over,anybody got ideas.
Cheers Eb.
x 1052
Re: Non Starter Xantia 110 hdi
Unread post by wheeler »
First thing you need to check is if there is a power supply at the starter solenoid wire when you turn the key to the start position.
It's fairly easy to access on this model at the front of the engine.
Big Eb
Ok thanks for your reply ,will give it a go
Big Eb
Sorry for late reply been away,was the battery as the alternator wasn't working like it should,cheers.
