Hello!
Have never posted before, but have gained so much help here in the past from reading others.
I have a 2011 Citroën C5 hdi 163hp.
180000km, have been running great up until lately. I have orange engine fault in my dash.
Checked out the faulty codes and gets the following:
P107a
P1497
P2562
It said something about low turbo pressure and I get the feeling the car is a bit slower in acceleration. Can this be the EGR?
Or what does you guys here say? Anyone that know this problem.
Cheers, Filip
Faulty codes Citroen c5 hdi 2011 163 hp - need help!
Der_Bomber1978
vladd.alex
- x 4
Re: Faulty codes Citroen c5 hdi 2011 163 hp - need help!
Hello. I have the same problem on my DS3 1.4 HDi. Loosing power, same error codes. What I have done was first to check the pipes and then the solenoid valve and the turbo actuator. Everything is fine. Then I did some tests in Diagbox and I found one issue. When starting the test called “Checking the pressurization of the air entering the engine”, I get every time an error called “air hose disconnected at flow meter end”. But there is no air hose disconnected and I hear no whispering. Also the turbo compressor looks ok. I figure it out that the power is lost due the fact that from 0-100km/h I need 23 seconds. It should be 12 seconds. Maybe you can also do some tests using Diagbox.
