I did a complete reinstall of the audio system in my Citroen C5 X7 (amplifier install, sound deadening, speaker replacement, sub-woofer in the trunk), wish you could hear it!
The only issue I have now is the remote-trurn-on wire, or the lack of it.
If I push the on/off button on the unit's panel to shut the radio off I can still hear amplifier's noise coming out of the speakers and it drives me crazy - it is not much, but it is still there. Plus, the amplifier should not be active if nothing is being played through the radio.
According to some docs I found RD4's Pin 11 is a "+12 v switched remote - the signal output to activate external devices (amp)",
but
RT6 which I have, according to post on this forum states that pin "11 Channel not connected".
So the question is: does RT6 have remote-turn-on functionality? but just "not being used"? I don't really feel like pulling the head unit out again to check that :/.
Cheers!
