Citroen Relay engine sound
Euanatkinson
Unread post by Euanatkinson »
Hi, bought a relay 2011 2,2 hdi to convert into a camper. Has a whining/ whistling sound on acceleration which gets worse higher revs, not always there but comes and goes.
I’m thinking the turbo needs replacing
Any help would be appreciated!
x 6957
Re: Citroen Relay engine sound
It may not be as catastrophic as that.
All turbos make some noise as they 'spool up', but if it whistling louder, then it could also be caused by the following:- a Turbo Boost, air or vacuum leak, a hose with a split in it, an overboost fault or damage to the compressor wheel.
Amigoo33
Unread post by Amigoo33 »
Find a source first!
