Unsurprisingly I've not driven my car in the past month. In order to keep the battery healthy can I hook it up to an optimate while keeping it connected to the car? Would like to avoid disconnecting the battery and going through the BSI reset if I can avoid it. I've used optimates on various cars and motorbikes in the past with no issues but my car is a citroen so who knows what madness I might unleash
x7 battery question
Bandit12
- x 12
x7 battery question
Hi Guys hope you are all keeping safe and well.
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone)
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade)
- x 1240
Re: x7 battery question
You can connect any 12v source to it providing you do it THE RIGHT WAY round, otherwise.
- x 6945
There are lots of models of these - but by all accounts they say that the higher voltage charging function is disabled if it senses vehicle wiring. If you have one of those that charges via the cigarette / accessories socket, I would forget that though, as the BSI cuts off power to it after a period of time.
I took mine off last month and gave it a good maintenance charge. I'll do the same again in a few weeks. I also disable the volumetric protection whilst the car is not in use by holding the alarm button in for a few seconds (right hand dash side 3-button cluster) until lit before locking the car. I don't need that protection where my car is and it saves power by disabling the internal movement sensors.
I have a Smart charger, but I prefer to charge off the vehicle - and in any case, a reset is good every now and then.
- x 3565
I've charged my C5 X7 innumerable times with a Lidl / Aldi intelligent charger without disconnecting the battery once. Never even had a whiff of a problem.
- x 1052
Absolutely no problem charging in situ with an Optimate.
Bandit12
- x 12
Brilliant, I'll hook it up and see what happens
- x 3565
