C5 X7 Hdi. No apparent turbo boost
x 1240
Unread post by Peter.N. »
Fitted a new starter to my red one a few days ago and did actually have to go out in it a day or two later, drove fine until I came to a hill. put my foot down and nothing much happened. I don't know if its something I have done or a coincidence, checked that I had plugged the MAF in, which I had, disturbed very little else. I have had it off before with no ill effects, any suggestions. Still don't have a working Lexia. :oops:
Another strange thing, I never did find out what was causing the intermittent wipers but every time I disconnect the battery when they are not working they spring into life again. :?
lexi
x 134
Re: C5 X7 Hdi. No apparent turbo boost
Unread post by lexi »
I can't help with your problem Peter. You are some man though in still messing with cars given your "maturity"?
Stay safe.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1056
Unread post by wheeler »
Did you disturb any air pipes to get to the starter? if so I would check none have popped back off. Can you hear any 'wooshing' noises when you rev it up? do you feel the air hoses puffing up when revved?
x 1240
Helps to keep me 'fit' Lexi.
All I disturbed as far as I know were the air intake pipes and filter box and the intercooler to engine pipe but I connected them again securely the only plug I disconnected was the MAF lead.
No urgency as it still drives and I have the other one anyway, I would just like to fix it.
x 1450
Unread post by xantia_v6 »
Check that no vacuum hoses have been pinched or fallen off.
x 1751
With no turbo available, your mpg figures, Peter, are set to become stratospheric! :monkey:
x 1240
That thought had crossed my mind Chris :-D Unfortunately for the immediate future I'm not going to be able to find out. Should have been going to Scotland next month. :(
x 1751
Maybe that's where we should hold our eventual "get together" (with Mick) then . . .?
x 1240
Nice quiet roads - like everywhere else at the moment!
x 2941
My experience of no turbo has been that the thin rubber vacuum pipes between the vac pump, the electrovalves and the turbo have split or are porous through age, splits very difficult to see without really careful examination.
That's barring of course the turbo itself being blown which would be apparent with the smoking exhaust.
x 1240
No smoke just a loss of power, I will check the vacuum pipes in due course. Thanks.
