MOT / CT
Steve Walsh
x 516
MOT / CT
Unread post by Steve Walsh »
Took the wife's C4 for its CT (MOT) today, In France they now plug in a OBD reader as part of the test. Never seen that before
moizeau
x 429
Re: MOT / CT
Unread post by moizeau »
They've done it since the regs changed in 2018
Pete
Steve Walsh
x 516
Re: MOT / CT
Must be the first car I have had tested with the new regs, It was a bit of a surprise.
x 1056
Re: MOT / CT
Unread post by wheeler »
Do they just test the engine management system? does any fault codes fail the test?
moizeau
x 429
Re: MOT / CT
They do a general test and if it shows a problem with emissions, air bag etc depending on what it is, it's a fail. I had a glow plug code thrown (cit HDI, normal), it was noted but with the comment 'not causing adverse effects to the environment' or something of that ilk. That was about 3 or 4 weeks ago. It's to stop people taking the airbag etc lights out of the dash.
Pete
Steve Walsh
x 516
Re: MOT / CT
Mine was low air flow, EGR. But still a pass.
moizeau
x 429
Re: MOT / CT
As long as it passes the general exhaust emission test they let them go
Pete
Steve Walsh
x 516
Re: MOT / CT
Emmisions came out good, I heard a rumour that the EGR has a blanking plate, but I believe it's against forum rules to discuss.
x 3566
Re: MOT / CT
Steve Walsh wrote: 22 Apr 2020, 20:21 Emmisions came out good, I heard a rumour that the EGR has a blanking plate, but I believe it's against forum rules to discuss.
Right, that's it, you mentioned the forbidden fruit. Up against the wall :-D
Firing squad - Alamy
Steve Walsh
x 516
Re: MOT / CT
