Horn Relay
slackgarry
Horn Relay
Unread post by slackgarry »
Afternoon, thinking of upgrading Horn. Does anyone know the rating of the OEM relay, Before i wire in a extra relay to feed the new twin Horns.
Kind regards
SlackGarry
Black 2008 C1, Petrol, 1KR-FE Engine. aka the GoKart
moizeau
x 429
Re: Horn Relay
Unread post by moizeau »
Is it integral or a removable one? If removable it should have a rating printed on it.
Pete
x 1751
Re: Horn Relay
I don't have a wiring diagram for C1 handy.
Looks like the original horns (one, or a pair) are standard Japanese disc-type, which can sound a bit uninspiring.
There is probably a relay already. To check whether there is, disconnect the horn(s), then press the horn button repeatedly and listen for a relay clicking. If you can hear one, it will be pretty safe to upgrade to a pair of Mixo's or similar. A bank of motorised Klaxons might need something extra, though!
If in doubt, fit a relay anyway: standard 12v 30/40A 'cube' type will do.
Possible that someone else may be able to find the circuit diagram for you.
slackgarry
Re: Horn Relay
Thanks for the help guys all working Very Manly Now. Disconnected the old horn it was fed via a relay. Soldered in a new earth and eye at the horn end and soldered in the live from the old horn.
Now works a treat and very loud. Got a pair of horns from a old Ford Focus from the scrappys.
Kind regards
SlackGarry
x 1751
Re: Horn Relay
Well done, you! Found the relay, and fixed the horns - double bubble!
