DS5 drivers door
zipdip
- x 4
DS5 drivers door
Hi all I have a annoying rattle from the drivers door has anybody had this and what did you do to cure it
2009 C5 1.8 vtr+
moizeau
- x 423
Re: DS5 drivers door
Don't know the car but I'd say to take the door card off and see what's rattling.
Pete
gwest
- x 20
I do note that my drivers door makes a knocking noise when being closed. It comes from the check strap, which seems to be a common failing with PSA vehicles. I haven't yet attempted to remove the door card to replace it.
- x 6950
take a video so we can hear the noise if possible. It is a creaking, grating popping noise, or is it something that rattles as in something being broken off and moving around?zipdip wrote: 20 Apr 2020, 16:18 Hi all I have a annoying rattle from the drivers door has anybody had this and what did you do to cure it![]()
If it's creaking and groaning when you open and shut the door, some silicon oil sprayed into the hinges and into the latching connections can help eliminate the noise. Or use some good marine grade grease to protect them.
If you think the middle one (called the door stop) has come broken off, it should be obvious as the door will swing without resistance and won't have any resistance to stay in the standard positions.
- x 1953
Check that any screws which fix the strap onto the body are tight if DS5 has any visible. If loose on other cars this can cause a cracking sound.
zipdip
- x 4
Thanks for the replys I tightened up a few screws and it has gone away for now
2009 C5 1.8 vtr+
