C4 VTS - Problem with the front seat backrest handle
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I stripped the left seat ( its a LHD ) tp replace the cushion and backrest. Now I have a problem. The handle ( circled in black ) of the backrest( circled in Magenta ) position is not function well. There are only two positions for the backrest - the one that enables a passenger to enter to the rear seat ( the backrest is folded frontwards as much as possible ) and the back most position at which the seat is almost 180 degree ( backrest and cushion almost flat ) . In all other positions of the backrest it will not keep its position. I didn't detach any cable - just removed the cushion and back rest and the handle. I guess something should be stretched before attaching the handle .The seat in the picture is the right seat , it is just to explain what I mean. Any help is welcome.
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: C4 VTS - Problem with the front seat backrest handle
Hi
It was resolved by pushing the backrest all the way backwards. If someone is going to strip a seat after removing the backrest angle adjustment handle the angle of the backrest should not be changed.
Zohar
x 3303
Well done for resolving the issue, and thanks for posting that information up here.
