DS 4 glove box light
metalhead_79
Unread post by metalhead_79 »
The light in the glove box won't come on.
Tried plugging in the light assembly to the foot well cable and there it works fine.
Any ideas?
x 6950
Re: DS 4 glove box light
Fuse F16 in the Glove box Fuse Box.
metalhead_79
Checked fuse and it was fine.
x 6950
Did you check it visually or actually test it with a multimeter? If you don't have a multimeter, replace it with a new fuse to make sure as you can't rely on a visual check.
Failing that you need to start tracing the wire back and checking for breaks.
