Turbo; how to replace?
lasjens
Unread post by lasjens »
The turbo in my newly acquired Turbo diesel seems dead; max speed 120 kph, and often a runaway engine on start-up running on engine oil; probably leaking from the turbo.
I have gotten at KKK to replace the Garret in the car, but how do I get to it? Can it be done in-situ or is the quickest to take the engine out? Any hands-on experience appreciated.
Lars Jensen
oilyspanner
Unread post by oilyspanner »
Which car?
Stewart
VLL
Unread post by VLL »
If its a ZX it can be done if you can get the car on a ramp or are prepared to lie on your back underneath.
Is a bit akward, as with everything on these cars but can be done.
lasjens
Sorry, it is a BX from 88'.
x 1466
Haynes alledges that it is possible, but on a car that is now 16 years old I very much doubt it! The fixings have such limited access on the BX, and are likely to resist attempts to undo them it will be difficult, if not impossible.
Pull the engine out, replace the turbo, replace the cambelt, change those awkward heater hoses down the back of the block, replace the clutch, replace the octopus. Consider taking the head off and replacing the head gasket. All of these jobs will be much much easier with the engine out, and should give the BX a good bit more life yet!
oilyspanner
I agree with Richard, with a few jobs to do its better by far to pull the whole unit out where you have the luxury of access and go mad replacing awkward bits (Esp rubber pipes)
Stewart
lasjens
Sounds pretty bad to me. I just changed the engine in my old 16V, which was a two day job for two of us..
So no easy shortcut...
mbunting
Unread post by mbunting »
As myself and timmsd found out with the Xantia, the air hoses are different shapes and connections between Garrett and KKK turbos.
oilyspanner
As are the oil feed pipes, make sure you get the one that comes with the new turbo (PS theres one on ebay, just run a search on citroen diesel)
Stewart
