Bad idle/hard to start warm - Citroën ZX 1.6i -92
oliverw
Hello there!
I'm totally unfamiliar with Citroën, but I've now owned this car for a month approxmatiely. I recently changed the timing belt, (or not me, a mechanic I know...). Car is running good, but now and then this engine light turns on (the one with a k-sign), but only when the car gets hot (working temp), also only when driving highway, so from 80 km/h.
It doesn't affect the driving anything, but it is annoying of course.
Starts perfectly cold, but can be harder when warm. Need to pump the gas a little.
So far I've changed spark plugs, ignition cables, oil and filter, fuel filter, air filter and today I changed the o2 sensor in hope that would be the main thing for my troubles.
But no...
Still have this CE light on, and smells also quite bad from the exhaust. Smells alot petrol, even though lambda is brand new (OEM Bosch).
And I have the 1.6i engine (65kw)
BDY (XU5M); BFZ (XU5JP); Petrol 88hp 65kw 1.6 i 03/1991-06/1997
But no...
- x 6957
Re: Bad idle/hard to start warm - Citroën ZX 1.6i -92
Do you have the VIN so we know for sure what it is you have - these are 2 separate engines.
oliverw
Hi! Yes, N2B40000B45514GiveMeABreak wrote: 21 Mar 2020, 19:14 Do you have the VIN so we know for sure what it is you have - these are 2 separate engines.
- x 5674
That seems to be missing some characters. Where did you get that from?
oliverw
Haha, that's the chassienumber I guess? But it's the 88hp model 65kw
oliverw
The engine looks like this :
- x 6957
The VIN is usually on the bottom left corner of the outside of the windscreen in a cutout. It will begin with V and an F and a 7.
oliverw
Okay, I will look it up. Posting it tomorrow, working at the momentGiveMeABreak wrote: 22 Mar 2020, 17:47 The VIN is usually on the bottom left corner of the outside of the windscreen in a cutout. It will begin with V and an F and a 7.
oliverw
When I look on car info they also refer to that number when looking VIN
- x 1751
The VF..... number is also likely to appear on the car's documentation.
ksanturion10
- x 19
Hi, had similar issuesoliverw wrote: 21 Mar 2020, 18:21 But no...
Have you managed to track your fuel consumtion till now? What do you pour in?
BR
Martin
Only himself the stupid makes wrong, many are being confused by the clever
citroenguy
- (Donor 2021)
- x 76
In the Swedish documentation the VF7**************[VIN obfuscated, can be read by forum staff] is usually missing on old cars (eg BX,ZX) , but in C-service you can always put in the 8 last digits an it will come up.
For this car i got VF7**************[VIN obfuscated, can be read by forum staff]
it is TU5M
I guess it has magneti marelli injection, so you should be able to get blink codes out of it.
it is TU5M
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
oliverw
Hi Martinksanturion10 wrote: 23 Mar 2020, 19:37Hi, had similar issuesoliverw wrote: 21 Mar 2020, 18:21 But no...
BR
Martin
Yeah, I'm gonna fuel him up today or tomorrow
But I've purchased a better used speedometer on eBay, and I really hope fuel gauge will work properly after change...
I was also in contact with a Peugeot/Citroen mechanic the other day. He was quite sure of the coolant temp sensor that is sitting on the backside of the head. Saw that the sensor and contact had a lot of old oil all over the place. Gonna clean up that and replace with a new one. Let's see...
ksanturion10
- x 19
Beeee, hi Oliver
well, if your really had changed all that stuff, that means you made a considerable funding, to where it should, and you might be deserving a little hint
First, don't know nothing about this model of Citroen, and I can only speak with relations to mine. So, what makes me an impression is the resemblance with the "petrol" smell, which is a bit awfull really.
One of the things I did, in my 3 month struggle with a non properly working engine, which kind of eased the smell for some time, was the removal of all the old petrol inside the tank, and pouring brand new fuel from a 10 L can.
Good petrol have definitive smell, which you should remember from your pre 90's stops at petrol stations, if some
Get a good electrical contact cleaner and go through any one out there, and also, keep your original parts if you are not buying an original spares.
I see you are resorting to an additional qualified help, so probably the best would be to keep it that way...
BR
Martin
BR
Martin
oliverw
Well...
A little update guy's...
The car is in need of a proper timing belt setting.
The mechanic I let work on the ZX didn't get the proper setting, because it runs bad on idle when warm. The idle first stalls like 3-500 (maybe) RPM but goes up right after and run pretty ok...
Also a little weaker at the moment. Takes like 1 liter or a little more. Were out on a trip and used the trip meter. Had like 400 km and filled about the same amount in litres (40l).
Otherwise good haha
I'm gonna let it be now and wait for the mechanic to contact me. And he's gonna fix it, trustworthy guy who also made the wheel alignment setting on each axle, front and rear.
//Oliver
Otherwise good haha
//Oliver
