Citroen C4 VTS - Light of parking sensor and ESP switch is not working
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
When turning on the car light the ESP and Parking sensor switches do not lit, as well as the door locking switch. The orange light on the switches are turned on and off when pressing the switch. I detached the switches and fed the light pins from external power supply and they do lit ( not surprisingly since the light source is LED ). Is there any fuse that if brunet will cause this ? Any other idea ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Citroen C4 VTS - Light of parking sensor and ESP switch is not working
Hi
I added a pic. The orange light ( circled ) turns on and off when pressing the switch.
x 1044
Unread post by wheeler »
Are you talking about the back illumination of the switches? Does everything else illuminate that should when the lights are switched on?
On the ESP button should be a 6 way brown connector?
Pin 5 is the earth & pin 1 should be a sidelight live supply. This comes from pin 7 of the 10 way black connector on the BSI via splice EV13 which is located above the steering column.
Best just to check all of the fuses.
lancia58
(Donor 2022)
x 8
wheeler wrote: 10 Apr 2020, 16:20 Are you talking about the back illumination of the switches? Does everything else illuminate that should when the lights are switched on?
Yes I am talking on the back illumination. But these switches and the door lock switch everything else illuminates. I detached the ESP and Parking sensor switches and applied power to the back illumination pins and in both the back illumination was on. You mean the fuses behind the ESP and Parking sensor switches ? Do you have the wiring diagram for the back light for these and the door lock switch ?
x 1044
Can you confirm that there is a power supply at pin 7 of the 10 way black connector on the BSI when the lights are switched on?
I mean checkall fuses including the under bonnet ones.
lancia58
(Donor 2022)
x 8
Do you know where is the BSI ?
x 1044
The BSI is the unit you can see in your pictures with all the fuses in it.
lancia58
(Donor 2022)
x 8
wheeler wrote: 10 Apr 2020, 16:45 Can you confirm that there is a power supply at pin 7 of the 10 way black connector on the BSI when the lights are switched on?
I checked and there is not a power supply at pin 7 of the 10 way black connector on the BSI when the lights are switched on.
I checked all fuses all OK.
Cemilayaydn
New User
Unread post by Cemilayaydn »
Hi. I have same problem how to fix?
lancia58
(Donor 2022)
x 8
Cemilayaydn wrote: 07 Apr 2022, 23:39 Hi. I have same problem how to fix?
Hi I still didn't fix it
vestine
New User
Unread post by vestine »
lancia58 wrote: 12 Apr 2022, 14:49
Did you fix it finally? I have same problem in my c4
