Xantia MK II - Cruise control not working
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
The cruise control is not working in my Xantia MK II. I checked the brake light switch on the brake pedal and it is OK. When the cruise control is activated I can hear a click of a relay but the cruise control will not engaged .
The cruise control vacuum unit ( bellow ) in the engine bay looks OK .
Any idea ?
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 3306
Re: Xantia MK II - Cruise control not working
I would check the associated pipes. I seem to recall somebody having the same problem, and there was a pinhole leak in a vacuum pipe which stopped the CC from working.
x 1451
Unread post by xantia_v6 »
Most commonly, the vacuum pipe splits just where it is pushed onto the vacuum pump.
Also check that the bellows diaphragm has not been punctured.
