C5 Bad starting/ loss of power
C5 and P2 2-8-2 fan
Unread post by C5 and P2 2-8-2 fan »
Just a quick heads up, I have had two C5's (mk 11)with problems which Lexia diagnosed as Electrovalve faulty.
The first was prone to not starting on random occasions but on being left a while would start ok; the second was loss of power when accelerating or on hills.
Both were attributable to the electrovalve (Right hand end of rocker box cover) not providing sufficient fuel flow.
The official Citroen part is, I believe in the region of £100 but the same part can be obtained here for much less:
https://www.ebay.co.uk/itm/FORD-FOCUS-M ... 1854063453
Hope this is of help if you have the above symptoms.
leithant
x 9
Re: C5 Bad starting/ loss of power
Unread post by leithant »
Thanks, it pays to shop around. I had similar symptoms but it was the fuel rail sensor.
06 Citroen C5 Estate 2.2 Hdi Auto
95 Peugeot 306 S16
95 Silver Xantia VSX - now deceased :-(
