Intermittent electrical fault mk1 Berlingo
andyneile
Unread post by andyneile »
This is a strange one. The last 2 days I've started my car in the morning and my date and time had reset. Car starts brilliantly so no obvious battery issues. Today the date and time had not reset but after 15 mins of driving the screen went blank and after another minute the radio turned off. It came back on itself after approximately 5 mins but did the same again. Any ideas ?
x 1931
Re: Intermittent electrical fault mk1 Berlingo
Unread post by Paul-R »
Did it lose the date and time when it reset itself while you were driving?
andyneile
Yes went back to zeros.
x 1056
Unread post by wheeler »
Have you checked for an insecure battery terminal?
What year is the van? surely its not a mk1 with a 1.6 HDi engine? didn't think the 1.6 HDi came along till at least late Mk2.
andyneile
It is a mk1 1.6 diesel and the battery connections are good. Vehicle is a 2009 58 plate.
x 1056
If its a 2009 model then its either a very late mk2 or a mk3. The mk1 finished around 2002.
Has it had any work done recently?
Might also be worth trying a BSI reset.
andyneile
It's not had anything done other than belt and pump about a month ago. I'll try a bsi reset.
