Turbo oil leak help please
Benscab123
x 3
Unread post by Benscab123 »
So, after having oil leaking onto the top of the turbo wastegate I was convinced it was just a poorly fitted oil feed pipe. I have now replaced the banjo bolt and copper washers and still have the leak. Could this be something as simple as the return pipe gasket not sealing properly or not tightened up enough ?
Only seems to happen when I go up hills, so assuming it’s when turbo is under more load.
Benscab123
x 3
Re: Turbo oil leak help please
Anyone ?????
doctle
x 225
Unread post by doctle »
is there wear on the turbo?
Oh buggle
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
New turbo from memory so no turbo wear
Benscab123
x 3
Fixed it finally, the clown who installed the new turbo neglected to clean the mating surfaces of the oil return flange, and even more unbelievably didn’t install the gasket provided !!
Shan’t be using him again.
admiral51
(Donor 2026)
x 391
Glad that bit is sorted just the EGR issue now ?
x 3301
Benscab123 wrote: 17 Mar 2020, 16:37 Fixed it finally, the clown who installed the new turbo neglected to clean the mating surfaces of the oil return flange, and even more unbelievably didn’t install the gasket provided !!
I could call him a Muppet, but I wouldn't want to upset Kermit and Miss Piggy!
