Egr diagbox?
Slobo2712
Egr diagbox?
Unread post by Slobo2712 »
Hi.How i can know is my egr valve good or bad?Here are shots from diagbox.
Car is going
Car idling
x 1488
Re: Egr diagbox?
The first one looks OK as requested position and reported position match, but in the second one the reported position is listed as invalid. You can't really tell from a static shot - you need to watch the two figures as you rev the engine up and down - they should follow each other closely, and the reported position should stay steady if you hold the revs steady.
Slobo2712
Re: Egr diagbox?
RichardW wrote: 02 Mar 2020, 07:18 The first one looks OK as requested position and reported position match, but in the second one the reported position is listed as invalid. You can't really tell from a static shot - you need to watch the two figures as you rev the engine up and down - they should follow each other closely, and the reported position should stay steady if you hold the revs steady.
Tnx,than I should record a video with parameters engine off,idling,going and post here?
x 1488
Re: Egr diagbox?
Yes, dynamic data is always more useful than static!
south74
Re: Egr diagbox?
Unread post by south74 »
Where is the EGR data within Diagbox? I am having trouble finding it. Which menu/option do I need to get live values?
Thanks in advance
Currently... Xantia MkII 3.0 V6, C8 2.2Hdi Excl, SM 2.7 ...and waiting for some TLC a DS23 Pallas efi. Times gone by... Xantia Mk1 2.1TD, ZX 2.0 16v, BX 16v, BX 19D.
x 6945
Re: Egr diagbox?
You need to look in the engine ECU live parameters IIRC.
south74
Re: Egr diagbox?
Thanks for the quick reply. (I am a bit thick though… sorry!)
Which menu is that under?
Repair >> ?
Fault finding >> ?
Maintenance >> ?
The screens shots above come from the repair section, but I can’t seem to find anything that takes me to live parameters.
Thanks for your help.
south74
Re: Egr diagbox?
Found it.
Fault finding >> expert >> injection/ignition >> standard parameter measurement >> air intake
EGR test:
Fault finding >> expert >> injection/ignition >> actuator tests >> misc tests >> EGR valve
Live graph test:
Fault finding >> expert >> injection/ignition >> actuator tests >> personalised parameter measurements >> EGR valve
