Peugeot 207 1.4HDi 2007
clivew
Unread post by clivew »
Hi, my first post, but been using members knowledge for a couple of years - thanks for that.
Thankfully not too many serious problems until now!
I have the dreaded water ingress in the engine fuse box. I am looking for a 9661708280 BSM-L11-00 and I can find plenty of them, but I gather from another post ( DHallworth ) viewtopic.php?t=61120 that there are different versions ( something like 6500FH )
but I can not see any number like this on my unit.
Is this number usually visible? How can I check a purchased unit?
Any information greatfully recieved.
Regards Clive
x 1751
Re: Peugeot 207 1.4HDi 2007
Pop your VIN here, Clive, and we can check the exact fusebox for the car.
clivew
thanks Chris
x 6963
The PSA part number for your 207 is: 6500FH. These are the other compatible international part numbers: 9664055780, 9664055480 or 9664055580. So search on 6500FH and then you should see one of these 96 numbers. You should also have one of these 96 numbers on your existing fusebox, either on the label or on the unit.
