DS5H Inflation Detectors
JINETE
Unread post by JINETE »
Now I find out which wheels don't have inflation or puncture detectors. The question would be whether I can equip them; my tires are 215/55 R17 93V :?:
x 6955
Re: DS5H Inflation Detectors
What is the VIN code of your car?
If it was sold as new after November 1, 2014, it will have to have a TPMS system fitted. Once you have supplied the vehicle identification number (VIN) I can see whether they were fitted to your DS5 or not.
Iansel
x 7
Unread post by Iansel »
For my education. Is this a genuine pressure measuring system or the version that monitors and compares the rolling diameter using the abs sensor data?
x 6955
I'm waiting for his VIN so I can see what, if any system was fitted. Most PSA vehicles 2014 and earlier were fitted with dedicated TPMS system that consisted of the TPMS wheel transmitters to a receiving unit and ECU in the vehicle. Later vehicles had the cheaper fitted versions without the wheel transmitters.
JINETE
Sorry 🙏 me VIN is VF7**************[VIN obfuscated, can be read by forum staff], and I'd like to know if I can take it thanks
x 6955
Ok, so I've checked your specification and the vehicle was not fitted with them. Your car was built 21st January 2014, so before the legal requirement in Europe.
JINETE
Well, go have a milk, and now what i can do is keep an eye on wheel roll is a can
Iansel
x 7
You can buy retrofit systems from Amazon for £25. No idea how good they are.
x 6955
The newer manufacturer systems are indirect - so they don't have sensors on the wheels. They use the ESP system wheel speed sensors to calculate variances in wheel speed that would determine if the tyre was under inflated.
But you can retrofit aftermarket sensors with a receiver unit that is mounted inside the car somewhere.
