Thermostat rating Xantia TD
P_C
Unread post by P_C »
Does anyone know what is the thermostat rating for a 1996 1.9TD Xantia. I think my car is running too cool when moving, so I'm going to change the thermostat in case it is broken to see if this helps.
The Haynes manual says a 1996 Xantia should have an 89C, however the motor factor I went to get the new one from said it should be 83C. I suspect the one fitted to my car is an 89. Did citroen ever change the thermostat rating at any time?
The running temps for my car are ~68C when moving and ~88C when in sitting traffic. Any suggestions?
AndersDK
Unread post by AndersDK »
There are 2 thermostat ratings around : a winter and a summer spec.
The summer spec would of course have the lowest rating providing an earlier opening temp for the radiator.
GSF would supply the correct one you need.
jeremy
Unread post by jeremy »
I had this problem when I change the thermostat on out ZX last year and was led to believe that all were 83C now - this being a modification. Whether this is true I don't know but the supplier assured me that was the case as did another factor who checked for me while trying to find a gasket and a friendly mechanic also confirmed this.
Certainly on the Zx a thick 'O' ring typr gasket was required - not the thin one supplied.
jeremy
