Hello!
I still haven't received the car, but I've read - I've heard from various people in the car that it's having a problem with the suspension - sashi especially in the comfort mode. Is it true? Has the problem fixed in MY 2020? Is it a construction mistake?
If that's the case, I'm thinking of canceling the pickup and asking for 3008 possibly hybrid 4...
Problem or not with rear suspension ?
- x 6950
Re: Problem or not with rear suspension ?
I think there was a member here who returned his as he wasn't happy with it 'skipping' over the road.
Did you not take one for a test drive before ordering? That's the only way you will be able to tell if you like it or not. Once you've ordered it - unless there is a fault, you will be stuck with it.
You could try a Citroen C5 Aircross with Progressive Hydraulic Cushion suspension, but you really need to take one for an extended test drive. Here is the UK, Citroen are offering 24 hour test drives on their vehicles, so might be worth looking at this before committing. But if you have ordered your vehicle, you may be committed, especially if it has customised options.
KonstantinosG
I take one ds 7 f?r test drive for 1 hour.I didn't feel anything, but it was a little bit of a time, and it's possible that the problem comes after several kilometers... The question is whether there is a problem or not... It's a shame to give 50000 € and have a car with a construction mistake
