Just bought lexia3 pp2000 diagnostics cable.
Spent whole day installing updating Diagbox software, and apperently v8.46 is the one which already accepts this unit, when trying to configure headunit parameters, program is trying to access psa servers. On forums some say that 8.15 was made to connect avoiding psa servers, but this version doesn't work with SMEG+i V2.
Are there any chances to get wmware image file containing preinstalled working Diagbox?
My car is 2008 Peugeot 1.6hdi 2016yr (facelifted). Car has SMEG+i V2 unit. After the 6.4.A.R10 update internet option has gone, and some speed camera symbol appeared which doesn't work. I updated software because my Samsung galaxy s9 phone couldn't connect with unit it was showing signature error. After update I was able to connect my phone, but it's useless. Now I bought Samsung Galaxy note 10 phone and signature error is here once again, but I haven't heard about newer update either, or there is one already?
Are there any offline Diagbox which will work iwth SMEG+i V2 ?
marteuk
- x 6945
Re: Are there any offline Diagbox which will work iwth SMEG+i V2 ?
No - direct from PSA servers for these.
marteuk
can I in that case using my own cable access psa servers? It probably would be still cheaper than visit dealer?
- x 6945
Not without an account - and if the vehicle was not configured with the SMEG +IV2 system originally, it won't work from your VIN. Also, once you go online, it will probably deactivate your clone.
Ideally, you need a sympathetic dealer, who knows the system, and is prepared to use the VIN form a known identical model fitted with the system to do the download - then all the other functions may need to be restored that are relevant to your own vehicle or there could be malfunctions.
These units are finished now anyway with the move to connected NAV - but good luck.
