2013/14 Berlingo van
ChrisRRR
Unread post by ChrisRRR »
Hi.
The drivers side brake light has stopped working.
Bulb ok and rest of light cluster works fine but there appears to be no current to the brake light bulb holder.
Can you tell me where the fuse might be?.
Handbook doesn’t help.
Thank you.
x 6954
Re: 2013/14 Berlingo van
I'll need your VIN to check out the Circuits Chris. Post it here (automatically masked in post submission). There may not be a user fuse for some lighting as these are controlled internally by the BSI. However, I would check the earthing point or the wiring feeding back. The left and right hand rear lamp clusters can have separate earths for each side.
