Hello, sorry for the stupid question but : i wanted to clean the maf sensor of my Peugeot 307 (engine EW10A) since i think it was never done but... i can't find it !
Even on servicebox software i don't see it.. it is possible that my engine use only the MAP sensor ?
Can anyone point me where i can find it ? (i've looked at the typical points, on the air intake hose and near the air resonator)
I've already posted my VIN but i can do it again if necessary.
THANKS !!!
does EW10A has a MAF sensor ??
- x 6957
Re: does EW10A has a MAF sensor ??
There is no MAF on your EW10A petrol. You have a MAP sensor, but the atmospheric pressure sensor is integrated within the engine ECU.
asaf400
- x 9
@GiveMeABreak
is the MAP sensor on the EW10A (RFJ), at the same rough location as it was on the XU10J4R (RFV)?
- bolted somewhere in the intake manifold, I think after the throttlebody and butterfly valve if memory serves (I repalced it on my Xantia)
I want to replace it on my C5 X7, I think this should be the part number: 1920 AJ
and this is what I wanted to buy: https://alvadi.ee/en/kataloog/varuosa/1 ... ct-tab-oem
Edit: formatting
Edit: formatting
- x 6957
Yes that is the part number and it's called the Inlet Air Pressure Sensor. Located behind the radiator fan assembly, to the right and just below the right-most pipe of the inlet manifold.
