Air Conditioner Compressor Clutch
vinc4299
Unread post by vinc4299 »
Dear All,
The air-conditioning compressor on my 1996 Citroen Xantia recently began to operate intermittently. I had the system re-gassed this week, but this had no effect. Although the fans cut in correctly which suggest a non-electrical problem, the fault was eventually traced to a lack of voltage being fed to the clutch compressor solenoid. Once a separate feed is supplied, say directly from the battery, the clutch clicks in perfectly. The garage suggested that it might be a faulty relay (i.e. dirty contacts) but given the number of unmarked relays, fuses I have been unable to find it anywhere! Would anyone know if there is such a relay, and its likely location? Any help would be much appreciated.
David
AndersDK
Unread post by AndersDK »
markxant
Unread post by markxant »
Hi David there is a relay that works the air con in the fuse box under the bonnet behind the battery its the mauve one if its duff or has dirty connections the air con wont work costs abuot a tenner from citroen hope this helps
vinc4299
Thanks for the advice. I didn't know where to begin looking for that relay!
David.
