Hi ALL !
I drive Citroen C5 2008 x7 2.0HDI since March 2019.
But from September, periodically, I meet some problems when I drive the car or even when it idle. It engine cuts off, so I use car inertia to get to safe place, stop and start the engine again. If I start the engine immediately after off, engine start well but when I switch gearbox to D it is blocked in D3 position. So I should switch of the engine, wait for 1-2 minutes after that, turn on the engine and all messages disappearing and bearbox works well.
Messages what appear when the problem pops up:
Engine Oil Pressure Low
Faulty GearBox
ESP Faulty
Automatic Parking Brake Faulty
To exclude the bear box problem I test my car at Midlands Transmissions - so is NOT the GearBox. They told me that is definitely something electrical..
What I observed is when I drive, this Engine-Stop happens when outside is very wet or raining.. It give me some ideas of causes but I would like to ask your opinion in this context..
Thank you in advance for all your advices!
Citroen C5 2008 x7 2.0HDI - Engine Stops. Multiple Faulty Messages When Driving and Idle.
- My Cars: 2009 Citroen C5 X7 2.0 136HDI aut
*2011 Peugeot 508 2.0 163HDI
*2007 Peugeot 407 2.2 170HDI
*2006 Citroen C5 1.6 HDI
*1998 Peugeot 605 2.1 TD
*Peugeot 406 3.0 Coupe
*1995 Peugeot 605 2.5 TD
*1986 Peugeot 505 2.5 D
*1991 Peugeot 405 Mi16x4
Re: Citroen C5 2008 x7 2.0HDI - Engine Stops. Multiple Faulty Messages When Driving and Idle.
Hi!
I have the excact same issue! Did you find out what was wrong?
Thanks!
Thanks!
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5644
No good taking it to a gearbox specialist at this stage. It needs diagnosing!muvic wrote: ↑15 Jan 2020, 12:27 Hi ALL !
Faulty GearBox
ESP Faulty
You need to take it to a mechanic with Diagbox diagnostics to get the fault codes read first of all and post them up here.
A problem with the ESP system will affect the Electronic Parking Brake, as the ESP ECU controls the EPB.
The engine oil warning is self-explanatory - put the car on level ground and check your engine oil.
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
this plagued mine for months! (and others I understand)
very much a 'modern car' problem it seems
caused me much anxiety!
Gearbox warnings, and car would only select 3 or R, with a hell of a shunt.
ESP, brake warnings, god knows what other warnings would appear within a second of each other, it was like Christmas day every time, almost comical
always at idle, or slow speeds.
fixed with a new battery!
John
John
Thanks jgra1!
Installed a new battery now. Will see if it helps!
Thomas
Thomas
Can add this information: Got these error codes when diagnosing at my local Peugeot/Citroën workshop; p0215 p1166 p0337 p1671 p0245 p1164 p1694.
As mention i have now changed battery. Guess I have to drive some weeks to be sure that the problem is fixed.
The workshop (who is new ti Citroën, but has always been a Peugeot dealer) suggested me to change the fuse box assembly behind the battery as that was a common fault on Peugeot 508.
