DS5 Gear Knob replacement
jaspabt2
Unread post by jaspabt2 »
Hi, put deposit down on a 16 plate DS5 Prestige 150, hopefully one I don't regret.
One thing I would like to do, is replace the top of the gear lever. The numbers have faded. Unfortunately finding DS 5 parts seems incredibly tough, so wondered if anyone knew what the part number was or where could buy one from?
Many thanks [-o<
x 6963
Re: DS5 Gear Knob replacement
Pop your VIN up here (it will be masked automatically) or the Reg and I will be able to get a part number for you.
MitchDS5
Unread post by MitchDS5 »
The one in the Citroen C5 Aircross looks very similar to the one in the DS5. Considering the relative popularity (and newness) of the C5, if it is indeed the same part, it might be easier to get.
This seems like a common issue with the lever on the DS5's (mine is also faded and shiny), maybe the newer versions will not suffer from this early wear.
I'm also interested in knowing about part availability and assembly effort/cost...
x 6963
Same goes for you Mitch - VIN required for parts.
MitchDS5
My VIN VF7**************[VIN obfuscated, can be read by forum staff]
x 6963
ok, so for Mitch: part number: 96703047ZD
The gear knob lifts off - no twisting - but may be tight so be careful not to be looking over it when you pull, or you may need some facial reconstruction afterwards.
MitchDS5
Thanks for the info :)
jaspabt2
Thanks for that Marc. Pick car up at the weekend so haven't got the documents yet. Looks the same as what you've posted above.
Is it just a case of pulling the old one off and pushing a new one on? Isn't the reverse gear mechanism incorporated somehow?
D0Z3R2K4
x 9
Unread post by D0Z3R2K4 »
x 6963
No! Don't get it from them! :shock: :shock: :-D Those rip off merchants want £162.07 inc. VAT - They are not official dealers either.
It's only £90.68 inc. VAT direct from Citroen. :-D
jaspabt2
GiveMeABreak wrote: 09 Jan 2020, 12:23 No! Don't get it from them! :shock: :shock: :-D Those rip off merchants want £162.07 inc. VAT - They are not official dealers either.
Only :shock:
earlam
Unread post by earlam »
I’m looking to replace the DS5 hybrid4 knob. It’s so in adequate lol I’d like to put a larger one on. Any ideas if this is possible
x 6963
Depends what system you have - may not be possible if you have the hybris piloted box. Pop your VIN up if unsure. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
