how to remove a crankshaft bolt rounded off
jsp
x 12
Unread post by jsp »
How to remove a crankshaft bolt that is rounded off?
I am repairing another TU engine on an engine stand but, the crankshaft bolt wont come off.
x 1240
Re: how to remove a crankshaft bolt rounded off
Unread post by Peter.N. »
If you can find a socket that is slightly smaller than the bolt and hammer it on, that would be the easiest way, if that won't shift it weld a large nut onto the head of the bolt, not only will that give you more purchase but the heat will expand the bolt, hopefully loosening it.
x 1919
Unread post by Paul-R »
If the socket is bi-hex (has 12 points) then a single hex socket might do the trick. preferably one that is a fraction smaller than the correct size - maybe an imperial of NF socket in place of the prescribed metric one.
DHallworth
x 163
Unread post by DHallworth »
The other option is a cold steel chisel and a hammer, hold it level with the bolt to mark it, then once it's cut a small groove in the edge, turn the chisel so it's almost at 90 degrees to the bolt and beat it with a lump hammer in the direction you'd be undoing the bolt in.
That method has saved me a load of times!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
Sloppysod
x 385
Unread post by Sloppysod »
Question, I do not know this engine, but is this a lefthand threaded bolt? Are you trying to move it the right way?
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
