Help me to figure haw to install a pni 288
introfusion123
I have a Citroen xantia x2 1.8 16v fabricaton year is 2000 , my issue is i not have ideea haw to install IT in my car, and i not have a service to help me around
My zone , can help me figure with some photo,s and instruction ?
First tine i try to install-it , but is locking and fast unlocks any answers ?
- x 6953
Re: Help me to figure haw to install a pni 288
This is a third part central locking unit - you really need to contact the supplier for fitting instructions. The only thing we may be able to help you with is a wiring diagram of the Central Locking system for your vehicle to help you fit it yourself.
We will need your VIN for the car to see if we have a diagram for you. Post it here and we will see what we have.
introfusion123
My vin is VF7**************[VIN obfuscated, can be read by forum staff]
- x 6953
Ok, so you have a XANTIA II 5 DOOR SALOON 1.8 i 16v 112 Manual gearbox 5.
Build date (RPO) is: 08458
Left Hand Drive
Engine: XU7JP4
Gearbox BVM5
ABS
Simple Central Locking
Leave it with us and we'll see if we can locate a diagram for you.
Left Hand Drive
Engine: XU7JP4
Gearbox BVM5
ABS
introfusion123
introfusion123
- x 6953
Ok, so here is the wiring diagram for the Central Locking on your Xantia. The second diagram just shows where the wiring looms are located. I hope this is what you need, hopefully you should have some instructions with the product.
Wiring Diagram
Hardware
6202: front left-hand door lock assembly
6207: front right-hand door lock assembly
6212: rear left-hand door lock assembly
6217: rear right-hand door lock assembly
6265: fuel filler flap lock motor
6260: boot or tailgate lock motor
8630: protection central unit (CPU)
Wires
M6212 : EARTH m6212
6243: LH door opening control
6203: Left-hand front lock locking + command
6213: Right-hand front locking unlocking info
6204: Right-hand front lock locking + command
6214: boot striker in signal
6244: Close left-hand door command
M6217: EARTH m6217
M6202: EARTH m6202
6241: left-hand door brake +
6291: Left-hand front lock locking info
6211: rear screen actuator control
6201: Left-hand front lock unlocking + command
6202: Right-hand front lock unlocking + command
6212: boot striker control signal
6292: Right-hand front lock unlocking info
6242: left-hand door brake -
M6207: EARTH m6207
6215: / diagnostic line / 6218: Door locking indicator light output
6205: Left-hand front lock deadlocking + command / 6208: Right-hand front lock unlocking position info
Location
Wiring Diagram
Hardware
Wires
M6212 : EARTH m6212
M6217: EARTH m6217
M6202: EARTH m6202
M6207: EARTH m6207
Location
introfusion123
so I have to lower the glovebox to get to the computer? And i need to disconnect a horness and plug the module inside ?
- x 6953
I really can't help you with the installation - I am not familiar with the PNI 288. if it was me, I would try and understand why my central locking is not working and attempt a repair to be honest.
Connecting any equipment to the vehicle has risks - and if you don't know what you are doing, I would leave it to an auto electrician as you could end up with the vehicle not starting....
introfusion123
im not have a electrician near me to possible help me
,this is the reason i try to install myself
introfusion123
im try to install-it because my keyhole is freezeng and i cannot enter in car
- x 6953
Ok, can you explain in as much detail as you can (use Google translate if it helps) and somebody might be able to help with the issue.
Does the remote fob work?
Does the key open the driver or passenger door manually?
introfusion123
except for the cold periods, I have no problems with the closing working normally, but once the cold weather comes I cannot unlock the car because it freezes the lock, a neighbor told me to warm up with the key lighter to defrost the lock, the fault is that once the freezer cannot the key exchange in the hub, in the hot periods I have no problem
I want to install the module because I want to avoid this problem by inserting the key into the driver's door hub
- x 6953
Squirting some silicone oil spray into the key lock barrel should help protect it from freezing up.
introfusion123
humidity inside of the car not let me to do that ,im was try that same issue
