xsara picasso 05 2ltr petrol Automatic. Plus and minus ?
jerseykevsweden
Unread post by jerseykevsweden »
Hi folks,
l am a little bewildered. In the engine compartment, in the middle-ish off to the right, there is a plastic piece with a plus and minus on it.
I am assuming this is if you need to connect jump cables unless someone tells me no its not for that. But what I don't understand, when l connect a volt multimeter, I get no reading which I find strange as if there is no power going to those two cables. I did put a little grease on them but surely that would not stop a reading. I appreciate a reply.
x 1942
Re: xsara picasso 05 2ltr petrol Automatic. Plus and minus ?
Unread post by Paul-R »
A photo might help identification if you can take one.
Michel
Unread post by Michel »
jerseykevsweden wrote: 27 Dec 2019, 08:03 Hi folks,
It is for that, but I also get no reading on my HDi version. When I've had to use jump cables on it, I attach the + terminal to the positive , and use the engine mount on the opposite side of the engine to clamp my earth cable to.
jerseykevsweden
Thanks, Still pretty strange no reading.
x 6957
There should be 2 terminals there - remote connections to the battery under the seat. This is what I have on this - but according to this you should be able to both charge and read the battery status - but as mentioned - don't use the earth behind the bonnet lock:
Figure ?: Location of the ancillaries battery:
The ancillaries battery is located under the driver’s seat
A remote terminal block (positive terminal and earth) is located under the bonnet (at "b")
CAUTION : Do not use the earth that is behind the bonnet securing hook; this screw being painted, it cannot be used for checking the ancillaries battery.
Figure ? : Checking the ancillaries battery using either a battery tester or a voltmeter (at "a"):
  • Open the flap for access to the remote positive terminal
  • Check the state of charge of the ancillaries battery using either a battery tester or a voltmeter (the black probe on the remote earth and the red probe on the remote positive terminal)
  • Close the flap for access to the remote positive terminal
Figure ?: Recharging the service battery:
  • Connect a Marque-approved charger to the ancillaries battery at "b" (the black cable on the remote earth and the red cable on the remote positive terminal)
  • Using the approved charger, commence the recharging of the ancillaries battery, keeping to the manufacturer’s instructions
jerseykevsweden
thanks for all the replies much appreciated in understanding now.
jerseykevsweden
Just a quick query on the matter. now I know that you only get a reading when you put the earth to the chassis or somewhere on the engine. and put the plus on the plus. When l initially said that there was a plus and minus in the engine compartment. l noticed today that it is only 2 pluses. And that's why l wasn't getting a reading Because l took it for plus and minus. Can someone explain why it is 2 pluses that sit together ??
