I have a problem with my car. Everytime i turn off, the engine stays on. Even after disconnecting the battery.
But when i press the brake or clutch pedal, then the car turns off.
Citroen xsara 2 1.4 (2005)
Anyone can help
Xsara 2 problem
ksanturion10
- x 19
Re: Xsara 2 problem
the alternator provides enough energy to sustain ignition, but you should never try to detach the battery while the engine is running, as there is great chance of experiencing even more electrical faults. Can't make relation with the clutch or brake pedal however. Maybe the currents found a new way round
, or someone had messed up the whole instalation.
Could suggest to check your "+" and "-" clamps for firm contact and then go from there.
- is it a diesel?
Only himself the stupid makes wrong, many are being confused by the clever
yan2303
Re: Xsara 2 problem
thanks... Does that mean the alternator is bad? will check the battery coneections.ksanturion10 wrote: 25 Dec 2019, 15:49 Hi,
the alternator provides enough energy to sustain ignition, but you should never try to detach the battery while the engine is running, as there is great chance of experiencing even more electrical faults. Can't make relation with the clutch or brake pedal however. Maybe the currents found a new way round, or someone had messed up the whole instalation.
- is it a diesel?
p.s: it is petrol
- x 1459
Re: Xsara 2 problem
It is probably not the alternator, I think that it is more likely to be a fault in one of the fuse boxes keeping power to the engine ECU when it should be switched off.
Has any work been done to the car recently that could have triggered the problem?
- x 1052
Re: Xsara 2 problem
have you changed any of the rear bulbs just before this started?
yan2303
Re: Xsara 2 problem
Yes, and i also just realised one bulb is not lighting.
- x 1746
Re: Xsara 2 problem
" Every time I turn off, the engine stays on. Even after disconnecting the battery.
But when I press the brake or clutch pedal, then the car turns off. "
" Have you changed any of the rear bulbs just before this started? "
Now this I can't wait to hear . . .
ksanturion10
- x 19
Re: Xsara 2 problem
Nevertheless, I think that diesels could also receive damage from detaching the battery while engine is running, despite they are self igniting!yan2303 wrote: 26 Dec 2019, 05:12thanks... Does that mean the alternator is bad? will check the battery coneections.ksanturion10 wrote: 25 Dec 2019, 15:49 Hi,
- is it a diesel?
p.s: it is petrol![]()
Well, didn't ever had such strange bulb problems
- x 1746
Re: Xsara 2 problem
The car in question is a petrol.
If a battery is disconnected (diesel or petrol) with the engine running, damage to the alternator (and the car's electrical system) is caused by the alternator looking for a battery voltage, which is doesn't find. This can cause escalating alternator output and voltage. The connected battery also provides stabilty and 'smoothing' of the alternator's 3-phase unsmoothed d.c. output, which the car's electronic and audio systems will not like.
ksanturion10
- x 19
Re: Xsara 2 problem
From what I know, and because the first thing I did for the car was the change of the collector rings and the brushes, most alternators are self excitating after each start of the engine.
