Hello, I have a 2008 1.9 Grand Scenic and the service light came on.
The error codes suggest it's a glow plug issue.
I've already changed the glow plugs but issue persists.
My plan is to
1. check the glow plugs fuse (I know I should have done that first - blush) but not sure where it is located.
2. if that doesn't work attempt to replace the glow plug relay which again don't know where is located.
Can you please point me to the location of the glow plugs fuses and relay and also suggest something else if you think my plan is wrong.
Kind regards,
George
Investigating glow plug issues - 2008 Renault Grand Scenic - 1.9
